chappy spark plug
What kind of spark plug should i use in my lb50 chappy? Also will 10w-30 moter oil work well in the tranny?
Re: chappy spark plug
Check out www.mopedriders.org, then go to the Moped Repair section THey have a Champion Psark Plug cross reference guide with gapping as well. good luck
there is no 1980 lb50 on that list. will a NGK B6HS spark plug work?
Don't use Champion Spark Plugs. NGK spark plugs work better. I own a Chappy and it is definately the B6HS spark plug.
