engine block moving
when i pull the thottle back on my 05 tomos lx the ngince block shakes once then when i hit the brake it does the same thing. also when i get to about 35 n my kit starts to kick in its ok but as soon as i let go of the throttle it makes this grinding noise. i dont know if its related to the engine movie or what.
Re: engine block moving
moving**
Steamboat Aka J. R. Stevens /
Most mopeds use rubber motor mounts. Check for loose/missing bolts/nuts and worn mounts or a broken weld .Jim
John Joedicke /
No rubber with the Tomos motor. Tighten up the 4 bolts.
