fill the transmission with fluid through the left side of the bottom end case, the plastic filler plug. DO NOT TOUCH THE LITTLE SCREW ON TOP LEFT BESIDE THE CARB!!! That's the fillister screw and if you unscrew it you'll have to open the entire case to fix your incumbent clutch problems
