tire replacement problem
so i need to replace my front tire and my rim i 2'' i have a tire that is 2 1/4'' can i use this or will it be a problem
Re: tire replacement problem
i think so, i dont think that it will sit correctly in the rim try it and see if anything bad happens but if you do put it on do go on a journy across country go slow so if something were to happen you dont die or worse crash your ped
People put slightly wider tires on their rims all the time without trouble. 1/4" difference isn't too extreme, that's only 1/8" on a side. If you mount it on the rim, and it doesn't rub on your swingarm or fender or anything, then it's fine.
I have 2.5's on my 2.25" rims without any problem. Just make sure it'll clear. Somebody here told me they had 3" fatties on their ped........
