Re: It doesn't start!
Chris /
It was running fine before, shouldn't be anything different, I guess i could pull apart the carb and clean it out though just to be sure. And the carb cleaner is a good method to kick start the engine sometimes, just be carful you don't seize your engine like I did once, don't use a lot.
