It doesn't start!
Steven /
I think you may not be getting fuel to the motor. Clean the carb or replace it, but first check compression with a real compression tester. I heard compression should be at least 120 psi for a 2 stroke. good luck, im working on my moped too. I got spark, compression, but no fuel. Its a carb problem for me. Im going to try that carb cleaner method tomorrow.
Steve
