QT50 oil in case...how?
How do you know if you need oil in the engline case? Mine has a oil "hole" with cap, but no dipstick? Is there an oil level "bolt" to remove and see a level?
Re: QT50 oil in case...how?
Hi Tom,
If you are referring to the transmission oil (left side of engine if you're facing the front of the bike), your best bet is to drain the oil (lowest bolt on the same side) and refill it with 30W engine oil, 1/3 qt. Now you know it's filled with fresh oil, and to the proper level.
Cheers,
-David
