Re: Quick Oil Question
keller_stephen /
Did not know you could run synthetic...usually there is a sricker that tells the mixture requirements for you bike..then google fueloil mix and it will tell you...always mix in a sep container whatever you mix is! Also I ad the required amount of stabil...(some use sea foam) to every gallon I mix up! Good Luck!
