Puch problems
I have been cleaning the engine to my 1981 puch maxi. When I took of my air filter, there was fuel in it. Is this normal? Also I have a slight crack in the rubber where my throttle cable connects to my carb. Is this a problem? Thank you in advance.
Re: Puch problems
boot crack normal no problem it just protects the threads on the cable , gas in the filter HMMMMMM not normal is it gas or cleaning solvent from your cleaning , does it run other wise and how well?
Re: Puch problems
Portland aint that far away guy im in hampton
Re: Puch problems
Jason Luther /
gas in the filter, inless its dripping wet, running all over the place is normal. when the engine runs a little bit of air/fuel mix blows back out of the carb
Re: Puch problems
I cant see how gas in the filter is normal it would have to travel a good 6 inches to get to the filter and thats through the air box space ,that much gas blow back is not normal
