Re: Honda PA 50 II
rad roni /
wow thats not right at all you should be doing at least 25, yeah i would check the carb again to see if your choke isnt on the whole time make sure that the lever you push down to put on the choke doenst stay on when you go full throttle, if it does then you need to take apart the carb again and fix that this happenede to me once before so this is my guess
