why wont it start
ok so i just replaced the condenser on my 79 moby
after i put everything back together it wont start
it does have spark but it is very weak
i cleaned the points and they are opening
im pretty sure its something electrical although it does have spark
would a weak spark prevent it from starting?
or is something else the issue
thanks
Re: why wont it start
so...anyone?
Check timing?
why wont it start
Steamboat Aka J. R. Stevens /
Was the bike running before you replaced the condenser? If so why did you replace it? Jim.
it was running for only for a little bit then it would run like crap
i was told this is probably because of the condenser so i replaced it
now i cant get it started
you mentioned a weak spark, check the connection between the spark plug and the spark plug harness or harness to engine if the spark is not the problem then it must be fuel, do a few back pedals with the ignition switch off and pull the plug if its not wet then youre getting no gas then you should check fuel lines and clogs in the carb
the plug was wet i already checked that
but ill recheck everything electrical tomorrow
You may have installed a worse condensor, Reinstall the old condensor. If the bike starts, the new condensor was bad. Jim
good idea ill try that tomorrow as well
actually the bike will run without the condensor...will burn points fast though,remove it,just to see if it`ll fire up
