tomos motor
i look under my ped a few weeks ago and realized that a exhaust stud snappd in the cylnder. the i went to pull it out with one of those tools and it snappd the tip righ off the pull tool. the after numorouse hours of drilling. i finally got it out. now the whole is much larger. what should i do ? -alex
Re: tomos motor
bump
Re: tomos motor
weld it shut
Re: tomos motor
it is cast aluminum.
Re: tomos motor
i only have a mig.
Re: tomos motor
simple. drill the hole in your exhaust to the same size (or even one size larger) and tap the hole in the bottom of your cylinder. Buy a bolt that matches your tap, and slap it on. That's what I did.
Re: tomos motor
and if that fails get another cyl.....
