gunk in exaust pipe
Hello just was wonderin why there is some gunk in the muffler?? It is like tar. I Just fixed the bike and never even looked at the muffeler. Not drippin Its just kinda there. Could i be running it to rich?? Or could the lead additive do someting like this? or is it normal??
1977 Puch Newport
One owner other than me
Everything is stock
Re: gunk in exaust pipe
If people run a bad oil and gas mix this can cause this..some carbon build up is normal. I run high octane fuel and quality oil ie. castrol or honda or yamaha etc..also mix your gas in a separate can and shke WELL! I also run a bit of stabil fuel stabilizer..some use sea-foam as well...Good luck to you!
oven cleaner... dollar store.. works wonders
Take off the exhaust and clean it with over cleaner is what I should of said your new.. to the forum.
So its ok to use a high octane fuel in the moped? I didnt know if that was ok. And oven cleaner wont hurt the pipe??
Cool thanks.
