Idle and Stalling of Sachs Westlake
I have a 1978 Sachs Westlake
I recently coated the fuel tank and cleaned the carburetor, but, have a problem with stalling at idle.
Any suggestions on what would make it continue to stall?
Also, will not hit peak rpm or top out as it hesitates ideas?
Please share any trouble shooting
Thanks,
Greg
Re: Idle and Stalling of Sachs Westlake
First, air filter, is it cleanish... a super dirty air filter will stall it at idle.
Second, you cleaned the carb, did you mess with the idle set screw?
third. won't go up to peak RPM, when was the last time you looked at the exhaust port? I just cleaned 1/16 of an inch of crud off my piston and head, there was only an opening the size of a pencil in my exhaust port window. the rest was carbon funk. An amazing difference was it was all cleaned out. I used fume free EZ Off. took 6 cleaning but it all came out of the head.
Fourth, I'd go looking at the point gap and timing, maybe even check your spark plug gap, or change it out.
Hope that helps
crackstar
p.s. do you have spoke rims or mags?
How's the gas flow, after kreeming the tank?
