Re: Slowness on a minarelli
joew /
you're asking for even more troubles if you modify a sick engine. the worst thing that could happen is you do something to mask the symptoms.. the problem still exists but is then invisible.
Mainjets control fuel flow rate at wide open throttle. Other carb systems meter fuel at lesser openings.
