Peugeot 103 stops sparking help!
🇮🇹💦 Of the Loin /
So I just got a rebuilt peugeot 103 coil in, slapped it on and hooked the rectifier up and it started right up ran and idled. I had to kill it by disconnecting the gas line, since I forgot to set up the decompression cable (no kill switch since coil is from a canadian model which didnt have it).
I fix the decompression cable and now it wont start up, and it looks like it wont spark. Im wondering if this is because its sitting in the sun and its probably about 90 degrees out and I just ran it and now its really hot, or if there is another problem I should check out.
thanks
Re: Peugeot 103 stops sparking help!
🇮🇹💦 Of the Loin /
oh and the condensor is brand new too
check the points
🇮🇹💦 Of the Loin /
points are good. If they werent set up right then it wouldnt even spark would it?
it could be light or hotter depending on the point gap closer is hotter
🇮🇹💦 Of the Loin /
ugh the points are kinda wierd, and the tips that connect came loose in shipping perhaps. Gotta work on them a bit. I got it running again time to fine tune
