bing carb, help
you guys helped me put the carb back together now it runs but only for a little bit. it sounds like its running out of gas. i got the needle on the second notch and i do have gas in the tank. any sugestions or idea on what im doing wrong?
Re: bing carb, help
Play with the idle screw.
Re: bing carb, help
played around with the screw and it ran for about 30 sec, then it sounded like it ran out of gas.
Re: bing carb, help
if you hold the accelerator will it stay on? if not then check the gas line for kinks> if no kinks then
disconnect hose from carb open petcock and see if gas flows steady> if so unscrew float boal and connect gas hose open petcock and when the float<little donut looking thing> is hanging down gas should start to flow and when its up it should stop.try that then check back.
Re: bing carb, help
disconnected the fuel line and open the petcock and nothing came out. i just cleaned it so i didnt think that was the problem. ill take it apart and do it again and pray to jah that its the problem.
Re: bing carb, help
got it running thanks to all who emailed me.
