puch maxi leaking gas
Hi all,
Can't figure out why i keep leaking gas from the carb. I have cleaned it numerous times, and studying closely, best I can tell is the gas is leaking from the black button right in the center of the attached pic (next to the air/idle adjustment screw. I need help desperately!
thanks
Re: puch maxi leaking gas
Check your float level, it may letting too much gas in. Take off the float bowl and turn the carb upside down. The float should be exactly parallel with the carb body. If it isn't, you can adjust it by bending the little brass tab.
Also, check the float needle (the metal thing attached to the carb float). If the rubber seal is deteriorated, it won't seal properly and will need to be replaced.
