bing carb reassembly
what is the propper order in putting the spring,needle,back together? do you put the throttle cable all the way throug the slide then hook up the needle? or do you hook it up in the slide?
Re: bing carb reassembly
put the needle in the slide first
The throttle cable comes all they way down through 6,7,8,9,10 and then hooks into the throttle slide (12).
http://www.themopedjunkyard.com/sachscarbweb.jpg
thanks guys got it running.
