spark plug hole stripped
bought a 94 sprint and the spark plug hole is stripped. how should i fix it??
thanks!
kev
Re: spark plug hole stripped
They sell rethreading kits at discount auto parts, auto zone, etc....There is one specifically designed for spark plug threads.
Kevin B. /
kev OP
cool....ill check it out!!
IM_THE_DARK_RIDER /
they are clled helicoils or something close to that they cost 38.00 for a kit
Of course keep in mind that a used cylinder head won't cost much at all. So you can replace it if needed.
Grey
I don't even think they were that much at my local store. Like 15 - 20 bucks.
Kevin B. /
kev OP
yea... i went to autozone and saw the heli coils. then i thought i should just get a new head.. my old head had a heli coil in it..
can i get a 18mm sparkplug? the hole is still there and i bought a chaser. do they make 18mm spark plugs that will work in mopeds?
thanks alot!
i've never seen an oversized plug for any vehicle.. and i doubt 18mm would do it.. probably need closer to 20mm.
if you sprung for a chaser, it makes me wonder how bad are the threads?
IM_THE_DARK_RIDER /
a chaser just follos origanal threds well use an a- head lol iv done it b4
John Joedicke /
Yes you can get bigger mm plugs. believe they are 18 mm as you said. See if the autoparts has a cross reference. I would just helicoil the head if the chaser doesn't do the job and look around for a used head from somewhere.
no kiddin.. i gotta ask next time im in a store.. might come in handy.
Kevin B. /
kev OP
yea... i am going to helicoil it and i ordered a new head from themopedjunkyard!!
Thanks for the help!!
kev
