Re: Tomos A3 Coil Rewire Fix
andy /
on a motorcycle the 3rd winding would be for the charging system,and is usually not as heavy (thicker wire) as the ignition and probably would work for a while,but not long term,I build dirt bikes and eliminate all but one wire,from that heavier winding up to the coil,splice in a switch if need be
