Puch 2 speed help
My 2 speed transmission is leaking fluid from the bottom. Should I replace the gasket and just change out the fluid? Whould that most likely fix the problem? If so what kind of trans fluid and how much should i use? Thanks for the help.
Re: Puch 2 speed help
check the gasket on the drain plug
Use type F transmission fluid.
is that type f as in the kind that is used on ford vehicles?
yep. The red stuff, the same.
Also, I think you should use about 30cc of transmission fluid for a two speed. I might be wrong though, check:
http://www.mopedriders.org/html/manuals/puch/sm/puchsm.htm
I'm sure it mentions somewhere in there.
does this manual cover the 78 freespirit's motor?
Not sure. I'd say yes, though.
It says in the manual that anytime tranny oil is changed you should change the gearbox oil also. What kind of oil should i use for this?
make sure its not over filled
the tranny and gearbox are one and the same.....
