Re: CALLING BLAINE!
PROCESS OF ELIMINATION
Re: CALLING BLAINE!
i took the carb off, reattched
the fuel line, turneed it on, and fuel came rushing out when the float is
down. i push the float UP, and gas stops, not one drop. then i let
the float down again, and gas comes out nicly..
FLOAT UP= NO GAS
FLOAT DOWN=GAS GAS GAS
i put the carb back on, reattached the line, etc..the fuel filter is
full with gas...but, it didnt fill up on its own..i had to blow in the
gas tank several times to get it full...i took the petcock OFF, and
its very clean. i blew threw the petcock hole to clear anything..then
put it back on. the header pipe IS clean. theres no carbon build up
anywhere on the pipe, baffle, exhaust. every hole in the header pipe,
restrictors, bafffle are clean, no black shit..
so the needle valve is OK (right?).
there is good flow of gas through the carb.
theres spark (but weak)
the air filter is good and clean.
jay
Re: CALLING BLAINE!
Jason I just came back from the store on my ped ,and guess what it started to bogg down wuuupwuuup so i reached down and pushed in the choke and it started to slowly come back to life try it if you can get her fired back up you know the rooteen
Re: CALLING BLAINE!
not starting anymore.
Re: CALLING BLAINE!
hows the plug look dri or gummy
Re: CALLING BLAINE!
ok i put a new plug in there, and it started right up..ran it around the block, and top speed (without the exhaust) is pretty nice..maybe 35mph or so..but this is how it was last time it was runnin, so maybe it wont run tomorrow..
Re: CALLING BLAINE!
Dont jinx your self always positive it wil run tomorrow it will run tomorrow it will run tomorrow
Re: CALLING BLAINE!
Dan, loL! isnt THAT jinxing your self? i mean, if you keep telling your self that something will happen thats not supposed to happen, its a self fullfilling profecy..
in the mean time, i missed English 101 class due to my moped not starting! lol!n and to he thinking positive..sorta..he he.
Re: CALLING BLAINE!
Bad boy! school first
CALLING BLAINE!
i didnt miss class, scholl hasnt started yet, im sayin that could be a possibility..lol!
