I was wondering if the maxi gas cap has a vent hole and were is it located?
expect a cap's vent to be tiny .. hidden.. up inside some nook or cranny.. so fuel cant splash out and rain cant get in. One vent hole is inside the cap's gasket and the other is outside.
but if the cap is not vented, the tank still has to be.. somehow.
the black cap has an obvious vent. the metal caps are hard to tell
Mine has a tiny little hole dead center on the outside of the cap, mine is metal , dont know what you have but if its like metal colored look for that tiny hole in the middle and you can actually blow threw it but very little it also looks like its clogged even though it isnt
they vent through the corregaterd underside. there are a couple different types of caps though, some have a hole in the center
