on a sachs 504/1a motor if so what dose it do because i looked on my suzuki's and honda and they dont have one.
one is cdi and one has points.
mine has points and a condenser whats a cdi?
might be suprising to a few people but actually, a magneto doesn't exactly need one to produce a spark.. but one is always used .. keep looking on the honda and suzuki.
A condenser does a couple things. It is capable of absorbing (and releasing) some quantity of electricity, like a bttery, only a condenser can do it instantly.
The condenser absorbs voltage spikes and prevents the points from arcing and so quickly corroding the points' contacts.
Is also strengthens the spark by speeding up the collapse of the coil's magnetic field. The condenser is able to very quickly absorb electrical energy in the coil's wire. The faster that happens, the faster the coil's magnetic field collapses, and the stronger the spark.
hmm ok i get it so i do need one in order for my moped to run _right_ im going to put it back in and do a few more things and if i have no lucky ill just order a new one
the C in CDI stands for capacitor, which is a modern technical term for a condenser.. if that tells ya anything. Capacitor Discharge Ignition.
in CDI, the points are replaced by an electronic switch and sensors that detect the crankshaft spinning.
"here's a pretty good, easy to understand basic info page":http://www.jetav8r.com/Vision/Ignition/CDI.html
yes you NEED it, Sachs engines will not run at all without it. I've gone thru a few on mine. Always the first suspect when it starts running shitty. The little black cap under the rolled over metal on top should "NOT" spin, wiggle or move. If it does it is suspect and should be replaced.
crackstar
