Re: help cleaning exhaust. dont no were to start
Daniel /
i aint that good with honda's but if that thing has a baffle in the muffler then u go ahead and remove that but if it doesnt remove the whole exhaust from the engine and you can use carb cleaner or I use something called oil eater or superclean
the super clean is available at most autopart stores just pour that in the hole and let it sit for a min the just rinse it out with ur garden hose do this a few times.
if it has a baffle you would take that out and use the same stuff just scrub it a little bit better.
that should help
