QT50 Break Change
hi,
i started changing the breaks on my QT50 this afternoon. the front one is in and the difference it makes is huge.
i cant figgure out thoguh, how to get the back wheel open. i took off the muffler, unscrewed the nut from the axel, disconnected the back part of the shaft, and couldnt get it open.
how do i gte in there to put in the new breaks
Re: QT50 Break Change
u just gotta beat the lil sucker a lil bit get a soft hammer and hold the wheel ip adn tap the bolt that u took the nut off
and it should pop off from the hub?
You need to completely disconnect the rear brake cable at the rear wheel, otherwise the wheel will hang.
