Re: suzuki fa50 frustration
Rusty /
Carlos,
There is a procedure for verifying the flow.
It should consume from .97 to 1.14 ml in 6 minutes at 2000 RPM.
You can use a large syringe pluged into the oil pump with a hose.
Remove the plunger from the syringe and plug it into the pump using a small hose, hold it up with the tip down fill it with oil and bleed out the bubbles if any from the oil hose and pump.
Run the test and see how much oil it used.
Note the oil pump should always be bleed when the hoses have been disconnected or the tank run dry.
There is a small philips head bleed screw on the front of the pump.
If this is not clear I can scan the page from the manual.
Rusty
  suzuki fa50 frustrationTopic by: Dave Campman Dave Campman 06/09/06 10:23PM
  Re: suzuki fa50 frustrationRe: joew joew 06/09/06 10:43PM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/09/06 11:09PM
  Re: suzuki fa50 frustrationRe: joew joew 06/09/06 11:46PM
  Re: suzuki fa50 frustrationRe: Mike Berkey Mike Berkey 10/15/19 11:39AM
  Re: suzuki fa50 frustrationRe: P D P D 10/15/19 11:51AM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/10/06 12:08AM
  Re: suzuki fa50 frustrationRe: Rusty Rusty 06/10/06 06:45AM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/10/06 09:24AM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/10/06 09:37AM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/10/06 05:19PM
  Re: suzuki fa50 frustrationRe: joew joew 06/10/06 05:53PM
  Re: suzuki fa50 frustrationRe: Rusty Rusty 06/10/06 10:05PM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/10/06 11:45PM
  Re: suzuki fa50 frustrationRe: ed james ed james 06/11/06 03:58PM
  Re: suzuki fa50 frustrationRe: carl carl 06/12/06 04:47PM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/11/06 11:42PM
  Re: suzuki fa50 frustrationRe: Aaron in Bellingham Aaron in Bellingham 06/12/06 01:45PM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/12/06 09:04PM
  Re: suzuki fa50 frustrationRe: Rusty Rusty 06/13/06 07:11AM
  Re: suzuki fa50 frustrationRe: carlos carlos 06/13/06 07:34AM
  Re: suzuki fa50 frustrationRe: carlos carlos 06/13/06 12:54PM
  Re: suzuki fa50 frustrationRe: Rusty Rusty 06/13/06 03:41PM
  Re: suzuki fa50 frustrationRe: Dave Campman Dave Campman 06/13/06 04:24PM
  Re: suzuki fa50 frustrationRe: Rusty Rusty 06/13/06 07:47PM
  fa50Re: Eric Eric 06/13/06 08:56PM
  Re: fa50Re: Rusty Rusty 06/13/06 09:17PM
  Re: fa50Re: Dave Campman Dave Campman 06/13/06 11:28PM
  Re: fa50Re: carlos carlos 06/13/06 11:55PM
  Re: fa50Re: Rusty Rusty 06/14/06 11:12AM
  Re: fa50Re: Dave Campman Dave Campman 06/14/06 12:42PM
  Re: fa50Re: Mitchell Mitchell 06/14/06 01:55PM
  Re: fa50Re: Rusty Rusty 06/14/06 02:13PM
  Re: fa50Re: Dave Campman Dave Campman 06/16/06 01:44AM
  Re: fa50Re: Dave Campman Dave Campman 06/16/06 01:45AM
  Re: fa50Re: Rusty Rusty 06/16/06 09:15PM
  Re: fa50Re: Harry Crank Harry Crank 06/18/06 03:11PM
  Re: fa50Re: Aaron In Bellingham WA Aaron In Bellingham WA 06/20/06 04:01PM
  Re: suzuki fa50 frustrationRe: derek heeks derek heeks 06/20/06 05:04PM
  Re: suzuki fa50 frustrationRe: Aaron Aaron 06/20/06 05:08PM
