Yamaha QT Engine Question
I have a Yamaha QT lower end (no piston, cylinder, clutch, carb, reed valve assy.oil injector or flywheel) that I am going to use for a rebuild and was wondering if anyone could recommend a good way to clean out the inside of the engine without disassembly? It appears to be pretty clean, but I'd like to ensure that there's no contaminants in the case before assembly. Thanks, David
