color uneven on spark plug
see attachment. same plug, different sides.
i pulled the plug today after probably 100 miles. half is white, half is brown. i've only seen them color pretty much evenly. what's causing this, is it indicative of a problem?
it's an FA50
Thanks!
:M
Re: color uneven on spark plug
I would guess that the side toward the exhaust port is running leaner. You could clean the plug, reinstall it, and put an index mark on it with a sharpy. THen you'll know the next time you check it. You better be careful if it's getting frosty white! Give it a little less air, or more fuel.
frosty white?!
i'll check on that. thanks!
:M
so you want to index your plug so the spark is on the side with more fuel (black soot), correct?
