Re: Something is wrong.
Anthony K /
Craig, I'm not sure if those symptoms describe a slipping clutch or not, but I would suspect some kind of carburetion/fuel flow problem first.
But, I wanted to tell you that you actually have two clutches, a starter clutch (which engages when you pedal fast enough) and your main clutch (which engages when the engine is turning fast enough.) So, even if starting without a decompressor has worn out your starter clutch, that wouldn't affect the main clutch at all.
