ciao speed question
Hello all,
So, just curious, how fast should a stock vespa ciao with the single gear transmission (not the variator) go? It's the deluxe model with turnsignals, not that that would make a difference, but anyway...
Thanks.
Re: ciao speed question
hey
take off your sidecovers. there should be a decal that lists the top speed of your vespa. 20 25 or 30
it will not be a 30mph, most likely a 25. you either have a 12.10 with a 11-1 or a 12.7 with a 14.1.
its really easy to swap a single speed hub and clutch with a variator and variable speed hub.
11-1? 14.1? What are these things? The gear ratio?
