puch questions
I have a puch E50 engine with some hairline cracks on the bottom half of the engine case that radiate from the oil drain. Can i still use the case? Should I replace it, and where do I get those cases?
Re: puch questions
fill it with tranny fluid and see if it leaks. i suggest you weld or soder those cracks shut
Re: puch questions
ya your deffinantly going to have to replace that, sounds like a big problem. the only place i can really think of to get cases would be off ebay.
Re: puch questions
may be a leak into the chamber though, wont leak tranny fluid from there...
have em welded on up.... super easy with arc, alum no problem
Re: puch questions
there's a puch motor on ebay right now, i'ts only at like $6 right now. i dont know if it's an e50 though. i'll try to find it again
-chad
Re: puch questions
