Re: jawa 40 - running problem
George Smith /
nah and especially not a jawa, you may have an issue with the ignition coil and or the lighting coil for it, it's possible that someone replace the lighting coil on the coil pack with a headlight one and that will cause exactly what you're talking about, i had a jawa doing exactly that then i opened it up and bang there it was, the coil with the red wire on the retaining ring should be smaller than the rest, if it isnt there's ya prob if it is, may not be a bad idea to replace it... also check your grounds if the only ground you are using is at or on the coil it will also cause this issue.
