1978 columbia loses power
***VANILLA BLUNDER*** /
i have a 1978 columbia commuter with the sachs, and when i get it top end for a while (22-24) and i lose foreward momentum and cant for figure out why, other than that it runs super good. anyone have any ideas why? also, i cant get above 23, but supposedly it can go 30. help a guy out!
Re: 1978 columbia loses power
p.s. i turn the trottle and nothing happens, and there doesnt seem to be any exhaust when its bogging down like this
the thing could be running out of fuel .. check for good fuel flow through the entire fuel pathway...
Inadequate fuel delivery will make the engine slow or die until more fuel has a chance to slowly trickle into the carburetor.
The rate at which a partly clogged fuel system slowly refills the carburetor bowl will determine top speed.
And the bike may run excellent below that speed.
From your description (no exhaust) it seems the engine is actually dying sometimes. But it otherwise "runs super good" ..
A whole lot of problems can limit top speed (clogged exhaust, closed choke, throttle cable adjustment, various ignition troubles, etc. etc.), but the things that would actually kill the engine at wide open throttle are very few .. i can only think of one at the moment.. a fuel restriction somewhere.
That bike is trying to tell you something in a nice, gentle way.. it needs a thorough tuneup. Listen to it.
I rode this bike and the problem is described to a T.
