Bing needle notches?
What are those little notches for on the needle that connects inside the round slide on a Bing carb? Gas flow?
Thanks
808
Re: Bing needle notches?
the needle is tapered.
as it is pulled farther out of it's "needle jet" more fuel is allowed to pass by it.
The needle primarily affects mid-range mid-throttle air:fuel ratio..
The notches allow you to tune the carburetor's mid range response..
A higher notch lowers the needle position. A needle that is lowered allows less fuel past the needle because a thicker part of the needle's taper is clogging the jet.
a lower notch raises needle position and allows more fuel to flow.
Go ahead and try it.. Take a run up and down the street.. Then change the notch position to the lowest and highest notches.. Get a feel for what needle position does around mid throttle..
☂Bob Hansen✄ /
bob OP
cool thanks i'll try that!
I'm used to Dellorto's from vespa scooters.
it dosent work the same w/a round slide.
Bob
Puddle Cutters M.C.
☂Bob Hansen✄ /
bob OP
I meant flat slide
