i got shocked
hello to all
i just finished some work on my ped and while fine tuning i got shocked by the spark plug
is this normal for when its running or is something not grounded correctly?
Re: i got shocked
hmm.. normal .. to get shocked.
I don't think so.
Double check your work .. focus on the kill switch and ignition switch wiring, or any other wiring related to ignition that you were messing with..
Re: i got shocked
If you had the plug out of the engine and you were touching it while you or someone else was kicking the bike then it is normal to get shocked. Were you checking for spark and got zaped a bit? This isn't unusual, you should just try to hold the plug by the insulated cable when checking for spark.
If you got hit while the plug was in the cyclinder from some other source then I would start checking your wiring.
Re: i got shocked
no it happened when it was running and i was messing with the carb then...ZAPPO
ill go check recheck my wiring
Re: i got shocked
after double checking i came up with nothing
the only thing i did was disconnect 4 wires
now they are connected(blue to blue,black to black, and so on) the way they should be
im stumped, any ideas?
Re: i got shocked
Small crack or pinhole in the spark-plug wire.
That's cool though, but a bit "jumpy".
Try one of these next time.... (attached)
---_DeeZy_
Re: i got shocked
any old wiring insulation?
Is part of a wire caught under the edge of a coverplate?
trace the entire length of the wires you were working on.. one of them is making electrical contact with the engine block.
Re: i got shocked
by "electrical contact" i don't mean direct contact with the engine..
for instance, an ignition wire that trails up the harness to some handlebar switch but has a fault and is touching the bars, does make electrical contact with the engine through the frame..
if you have a multimeter (ohm meter..continuity meter) dust it off and drag it out... it'll make things easier.
Re: i got shocked
thanks for the suggestions
ill keep you posted
Re: i got shocked
This happened to me once.
I suspected a short and leaned over the seat grabbed the rear wheel and pulled up, Got me a good jolt that made my arms clench.
Hurt too and I'm no sissy about electricity.
Fire it up in the dark, look for a arcking plug or coil wire, listen too you may hear it snapping.
Rusty
Re: i got shocked
Good points, Rusty.
