Speedometer
After about a year of battling my 1980 Batavus Regency, I FINALLY got it running...and it is awesome!!!
However, a minor issue. The speedometer/tachometer doesn't register anything. I checked out the connections and it looks to be a single cable to the front wheel. How should it be hooked up?
Thanks
Re: Speedometer
Ben Van Zoest /
To the sender unit on the hub, either mechanical or electric.
Check the Photos section for reference..
Re: Speedometer
I do not believe it is electric. There are no wires connected. Just the cable.
Thanks
Re: Speedometer
steveintoronto /
cable is probably broken inside the casing
