Motobecane Clutch Removal
Alright, so I have really worn out pads on my clutch and I took off the cover and what not. I have a new clutch and want to replace it but I cant get the countersunken screws out with a regular driver. In the manual it says that I need an impact screwdriver but I cant find one that'll fit.(all the ones people have are for huge bolts and clutch bolts are small) does anyone have any experiance with mobylette clutch removal? do I really need an impact screwdriver? any help is apreciated
Re: Motobecane Clutch Removal
Mike Scouty McScoutington /
do you just have the clutch arms? i have taken them off without an impact driver. the screws were set with an awl so thier is a little piece of metal that was pushed over to hold them in place. put a scrwe driver bit into a socket and use a ratchet to break the screws free. after you put the new pads on use an awl to set the screws. it says how to do that in the manual.
Here is a photo montage in French that walks you through the whole process of disassembling your variator.
from Ventilexp.com break>
You can use babelfish to translate the whole page, if you like.
