My Garelli Is Having Some Problems
I am desperately in need of help.
I have done everything i can think of. My Garelli Rally Sport will start but it will not idle.
It constantly goes at least 10 miles an hour.
I have adjusted the idle and am about to adjust the throttle.
I have good compression, a nice spark, and just got done having my gas tank cleaned/ re-coated.
I also replaced the piston rings and got the carbon out of my muffler.
Any suggestions on what i should do next.
Re: My Garelli Is Having Some Problems
To add to that.
My carb is cleaner than clean.
Leon Swarmer /
sounds like teh carb slide isn't cosing far enough. pull the air cleaner off and look in the carby throat. There should be just a very little gap at he bottom.
Look for cable housing that isn't properly seated at the twist grip and at the carby.
Leon
you rule
Walter Kravitz /
I would also suggest the carb slide is not closing all the way. Mine did that for a while, I had to readjust the spring seating. Also check your cables to see if they slide. A stuck throttle cable will act like a stuck carb slide.
zack is on the attack. thank you for the help
