Hi, I am still having problems getting my 1978 Intramotor Gloria Minikid to run right. I can get it to idle great, but when go to give it gas it just "bogs". I can have the throttle wide open, and all that it does is only rev up slighty."Bogs". My gas is good, my plug is new, and my carb is clean so i know that a dirty carb and bad gas has nothing to do with it. I think that it could possibly be fuel starvation because my carb is leaking gas at a steady stream where the fuel comes into the carb. I plan to put some gasket cement on the leaking area, but i do not know why it is leaking there because it has not leaked at all in the past. Maybe my float is getting hung up? However It is free though when I take the carb apart. Does anybody have any idea what the problem could be. I also checked the plug and realized it was black.
Thanks,
Jeff
P.S. I believe the carb is a Dellorto. I would also like to know the common jet setting for this carb.
