Re: Putting a 13/13 Dellorto Carb...
imonfire /
Justine....as far as i know...The dellorto carb i meant to be used with a single ended throttle cable that has a small head to fit into the carb (properly of coarse), and the other end is or should be open. So there should be nothing on one end of the cable. Because of this im not sure if you can use the carb o your moped. If the ends going into the carb doesnt fit into the plate in the carb correctly then you can always file it until it does. However, there may be other ways to do it so dont give up hope. I would try to find some people, if there are any, that have found ways to use double ended throttle cables with dellorto carbs.
