maxi making grinding noise
when i start it or when i ride it it makes a grinding noise but i guess that comes with it when it sits for 8 years.
Re: maxi making grinding noise
is it a 1speed or 2speed? 2speeds can making grinding noises and be ok. usually due to bad tranny fluid or just old gears and bearings. however if a 1speed is making noises you might have a big problem. are you sure you arent just holding the clutch in too long?
its a two speed and im shur it is rily loud in im concernd it only doset when i startet it. or when it runs.
any grinding noise energizes me to find the cause of it.
My Maxi made a grinding sound especially when i slowed. I found that the drive chain was adjusted too tight. When I loosened it slightly the grinding sound went away..
ive had a flywheel come loose, and it only made that noise when i was going slow, or idling....
lee
See Ya Moped Army /
Might be rusty crank bearings.
I replased the whol moter withon that was just sitting around all better but i cant get aney pipe to fid i take the heat off then put a maxi head on but it wuld not slid on then i tooket off and the cylnder fell apart now i need smone to put the new one on.
I have alol the parts.
Ben Van Zoest /
Yep, all bearings got crusty, motor, wheels. I would not run the thing unless you do a complete overhaul or if you only want it to run for a week or so don't bother...
