Actully it only seems you are advancing the timing because of the different position of the stator plate but since the new piston stroke is different because of piston size and or wrist pin location differences from the stock piston the timing measurement "Piston top to TDC" is actuully the same measurement .Now if you had the stock cylinder and piston on there and had the stator in this new position it would be advanced.Jim
