I had to pop off the flywheel so I could get a good angle for the screwdriver so that I could loosen the screw. Popped it back on and adjusted it there.....
On the flywheel where the points rub against it there seems to be some corosion right where the lump is to open the gap. I sanded it downa bit because it was rough and looked like it had worn down my points quite a lot since they are practically brand new and already gone done a bit...
I saw thatbrush thing on the other side......I was wondering what it did......what's lubing it for?
thanks
-nicco
ps.
can you actually put a cdi in a puch maxi?
