Tomos Idles, doesn't move
Periodically I start my tomos, with SIXTY MILES on it, and it will idle fine, and maybe even run around the block. But then I'll notice the power dropping off, and then I'll have to come to a stop. When I pull the throttle again, it will increase the speed of the engine for about half a second, and then begin dying. I let go of the trhottle and the thing goes back to idling, happily all day long.
I tried futzing with the engine speed nut thing, but that doesn't help.
Can anybody help me?
--Scott
Re: Tomos Idles, doesn't move
You might try cleaning your carb, its an easy thing to eliminate. Also make sure the spark plug wire isn't leaking.
Grey
Live to ride, Ride to work
leaking????
could just be as simple as a clogged gas cap
steveintoronto /
your bike is starving for fuel. go through the checklist and find out why. i like the cas-cap hypothesis personally.
Yea, I had a tomos with a leaking plug wire, the spark would jump out the sides and arc to the closest metal or finger. It would idle great but when I revved it up it would arc and die.
Grey
The odd thing is that it's done this before, but it always fixed itself.
So, clean the carb, check the wire. Or just ride a bike. The bike thing is quitter talk, though, and given that I sued somebody for twenty bucks, I'm not a quitter.
Thanks for your ideas. I'll see what happens tommorow.
--Scott
