Re: 1978 Puch "Free Spirit"
Conrad /
the front sprocket is a 13 tooth....where can I get a 16 tooth sprocket? also I believe the jet size is whatever came stock......I had to adjust the needle in the carb. It was at the very top notch so I tried the bottom notch and it ran fine till the next day when it would run but not idle....then I adjusted it one up from the bottom and it seems to be running fine......except I can't give it full throttle or it will bog down...should I go up one more notch or is there another adjustment for this?
