alrighty..i got my new motobecane and the acceleration is kinda slow....seems like the variator shifts to soon....anyway of fixing this...or another way to gain better acceleration.
does the dellorto 14/14 carb fit on a 40v?
oh ps.....i forget....what does which
smaller rear sprocket = better acceleration or top speed?
smaller rear sprocket = faster top speed
larger front sprocket = faster top speed too.
whenever I think of gearing, I remember riding a bike with alot of speeds, and watching the chain jump to the next sprocket
I have heard that removing a ball from the variator makes it shift later, I have not tried it. it is very hard to remove them. The cheek nut is always wicked tight.
you also need a pretty specific set of circlip pliers to get the clips out without ruining them.
Craigery, I put a 14/14 on my 50V (same engine setup, I think) and it has been a headache. I bought a bent intake to replace my smaller, straight intake, because it was the right diameter (19mm); but it put the carb in a place where it strikes the frame when the variator is pulling. So, I had to make an additional manifold piece. I would have stuck with the Gurtner, but it was leaking everywhere possible.
