Re: Motobecane lights not working
joew /
stick a volt meter on the headlight socket's leads.. run the engine.. headlamp switch 'on' .. if you got no voltage a wire is broken or disconnected somewhere down the line.. my guess is the fault is in a central location and affects more than the headlight.
hopefully the magneto's lighting coil is ok .. check that too... for coil continuity and/or for voltage off it's main output wires.
