honda clutch help!!
ok ive got a 1966 honda ca100 (early c50 ) and after spending 5 hours drilling out the engine casing nuts i discovered that the clutch is covered by a large cover stopping me gaining access to the clutch plates, i need to lock the gearbox up so i can get a turn on the nut inside to release it. whats the best way to lock the gearbox up
Re: honda clutch help!!
i dunno.. try a copper penny jammed into the gears. Why don't you buy a MANUAL
sounds like you're headed for even deeper water..
Release the gear drum, and put the gear box in two gears at the same time.
grz Thijs
Put it in 4th gear and have someone step on the rear brake while you wrench on the nut.
